soni
Rep Power: 14 ![]() |
Hi I am trying to make grid of a turbine which was modelled from blade modeler. I am using gridgen for that but I am not being able to refine the grids at the blades.I am making structured mesh.The cells get skewed and and when I make a mesh check on FLuent,it fails.So is Gridgen a proper tool for meshing a turbomachine?I have turbogrid now.But if it works on gridgen I wanted to do it on that.Can anyone please suggest me!!! I would really appreciate..Thanks!
Use TurboGrid, It is lot easier than working on Gridgen. As TG will do many tasks automatically, on the other hand in Gridgen you have to do every thing yourself. It is to be noted that Turbo-Machinery have curved geometry at hub and casing, which makes them very much difficult manually.
soni
Thanks for the reply Far.But I have iges file of the whole turbine.I went through the manual of turbogrid,it requires curve files.Are these curve files generated in Blademodeler?CAn I use my IGES file for turbogrid?
Use gridgen for this purpose. Put 200-300 nodes on the periphery of turbine. plance 5-6 nodes along span wise direction. make the domain on the blade surface. Now you will see the 5-6 airfoil with mesh on them, take these coordinates and past them in turbogrid file (profile). Similarly work on hub and shrould and past these coordinates in the respective files i.e hub.curve and shroud.curve
John Chawner
Rep Power: 18 ![]() |
Hi Soni:
TurboGrid is a great program for meshing bladed geometries, especially those that come from Blade Modeler. After all, the two programs were designed to work together. Plus, I know the guy who wrote one of the original versions of TurboGrid. However, I'd like to point out that Gridgen and Pointwise are very well suited for turbomachinery meshing which is why it's one of our largest markets. We have several people on staff with turbo experience so if you want to exchange ideas about meshing, don't hesitate to contact our tech support at support@pointwise.com. Best Regards
John Chawner / jrc@pointwise.com / www.pointwise.com Blog: http://blog.pointwise.com/ on Twitter: @jchawner |
soni
@Far:thanks for the reply Far.I dont have database for the curve passages.IS it possible to make it on gridgen or do I need to make it on blademodeler?Thanks
@John:Thanks John.I have contacted Wenny for this matter. |
you can make the mesh in gridgen as well. If you have some script then It will be very easy to make mesh, other wise it is not as straight forward as making mesh for the 3-D wing. Same goes for the ICEM CFD. I should say it is a painful job of couple of weeks or so.
But if you have turbo grid, it has built-in function for generating high quality meshes for the rotating machinery in couple of minutes or so. For this you don't need to have the data base in the gridgen. If you have connectors/domains or data in the x,y,z format you can easily setup the turbogrid file. Let me know if you need detailed help in going from one program to other. |
soni
Thanks Far,
Can I send you the file in your mail.So it's easier for me to explain my question? |
#9 |
soni
Hi Far,
Can you please take a look on the attached file. Last edited by soni_sth; October 17, 2011 at 18:22. |
#11 |
@John Chawner: If you can send him the TCL/Tk script for turbo machinery, then It would be much easier for him to make the good quality mesh in couple of minutes I guess? I know Gridgen is very very good mesh generation software for CFD and FEA.
@soni_sth : If you have the PointWise license and can get the special script (TCL/Tk aka Glyph) for your geometry, then I guess you will be in the good position. But definitely I share my experience that how to transport data from one code to other as I have the good experience in working with gambit, Gridgen, Turbo Grid and ICEM simultaneously. |
#12 |
vij
Soni I have similar issue.Please check the PM.
#13 |
soni
Hi Far! I tried to export the file from gridgen.They can be exported as grd file but turbogrid requires in .curve format.
#15 |
soni
It was built in blade modeler.I hve an iges file.I used gridgen to make a mesh.
#17 |
soni
That's what I am trying to do Far.I have a database file.I don't see any option in gridgen to change in .crv format.
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
mesh generation for in-cylinder fluent simulation | hennas | ANSYS Meshing & Geometry | 2 | May 31, 2011 15:08 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 13:47 |
