2-way FSI (steady)
Old   October 10, 2011, 14:44
Default 2-way FSI (steady)
Lingdeer
lingdeer is on a distinguished road
Hi, I m running 2-way FSI with steady conditions, which will eventually used as initial condition for transient FSI.
Is it ok if I used transient structual instead of static structual to couple with CFX in ansys workbench?
Thanks!
lingdeer is offline   Reply With Quote
Old   October 11, 2011, 06:44
Matthias Voß
mvoss is on a distinguished road
AFAIK 2-way coupling needs a transient struct. approach. What do you mean by "steady conditions" (inflow, pressure e.g.)?
neewbie
mvoss is offline   Reply With Quote
Old   October 11, 2011, 10:53
Lingdeer
I am using ANSYS CFX with ANSYS workbench to setup the solid part.
I am running with steady flow boundary conditions.
Thanks!
Old   October 11, 2011, 14:08
stumpy is on a distinguished road
Using transient structural is OK for this. It's actually better to use transient structural for the steady part if you intend to later switch it to a true transient, since it makes the switch easier. You can turn off time integration in the transient structural analysis if you want to get steady behavior, then turn it back on when starting the real transient. When you start the real transient note that it won't be starting from time = 0, since some "time" will have been completed in the "steady" part.
stumpy is offline   Reply With Quote
Solver for transonic flow? Martin Hegedus OpenFOAM Running, Solving & CFD 22 December 16, 2015 04:59
steady state FSI - error code 3840 alinik CFX 3 August 13, 2013 03:15
Two-Way FSI steady state k_buz CFX 0 April 12, 2009 18:17
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 11:30
