how I can write the file script to submite via HPC cluster at my UNI |
October 16, 2011, 02:06 |
Safia
hi there
see please the below link: http://hpc.usq.edu.au/documentation/...es.htm#ansysex it gives example for batch script to run ansys-fluent 12.1.4 on HPC cluster. As you can see, it has been written on the third row that: Please save this script into a file called (Fluent121.script) and # Submit this script using the command: qsub Fluent121.script what kind of programm which can open the files with script extension? finally, help me ASAP. Regards |
October 16, 2011, 17:19 |
Rep Power: 143 |
The link is broken. And you should post this request on the fluent forum anyway.
October 17, 2011, 02:18 |
Ali Torbaty
if it is required to submit via qsub, then the HPC is running on Linux; you can open script file with any text editor. the extension is not important in Linux like windows, it is the attribute which is important and tells the system if your file is executable. search around and you will find a lot of document for it.
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
