November 12, 2011, 17:50 |
How to visualize highly distorted mesh
Lingdeer
I am running 2 way FSI simulations and my simulation crashed as I lower my young modulus from 1e7 to 1e5. (1e7 worked but 1e5 crashed). The error is failure in reading mesh displacement, because of highly distorted elements. I wonder how can I visualize and check the region where the mesh distorted/collapsed to see how I can improve the mesh to improve the results. I read the CFD post manual but it is unclear how I can visualize and fix the mesh.
Thanks a lot! |
November 13, 2011, 16:55 |
Rep Power: 143 |
So is your question how do we view the mesh, or how do I see what is happening to find the problem area?
November 13, 2011, 17:18 |
Lingdeer
Yes. I want to know where is the location of the problematic area and what is causing the problem. Thanks!
November 13, 2011, 18:19 |
Rep Power: 143 |
If the run crashed before it wrote an output file then re-run it with a finer time step and saving an output file every time step. Hopefully that can capture the mesh motion enough that you can pick what went wonky.
November 13, 2011, 18:23 |
Lingdeer
Thanks ghorrocks. The funny thing is when I reduce the time step the simulation tends to crash and stop at earlier time step than using a coarser time step.
Also, in some cases the simulation just crashed at the first time step before writing any output file. |
November 13, 2011, 18:28 |
Rep Power: 143 |
Then your model is highly unstable. I would use a E which is more likely to work (maybe 1e6?) and that might give you a clue as to where the problem is.
November 13, 2011, 18:31 |
Lingdeer
Cool~ Thank you very much! I will try it out.
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
