Particle impaction on surface
Like Tree1Likes
  • 1 Post By ghorrocks
Old   November 14, 2011, 17:47
Default Particle impaction on surface
Julian Krick
Julian K. is on a distinguished road
Hi!
I am modelling the impaction of particles on a circular cylinder. My problem is, that the particles are not captured, although the distance of the particle's center to the cylinder's surface is less than 1/2*radius_particle. Thus my question:
When does CFX realize, that a particle hits a wall? When the particle's center coordinates coincide with the surface coordinates, or when the distance btw. particle center coordinates and surface coordinates is less than 1/2'particle_diameter?
FYI: I use Lagrangian particle tracking and the 'stick-to-wall' boundary condition for the cylinder surface.
grid generation: ICEM CFD 13.0
solver: CFX 13.0
Julian K. is offline   Reply With Quote
Old   November 16, 2011, 08:44
Julian Krick
I printed the tracking files and look at the final coordinates of captured particles. I found out, that this final coordiante lies on the collecting surface. Thus, CFX does not consider the particle's radius when checking for impaction (wall BC: Stick-to-Wall; Equation dependent with both restitution coeff. = 0 and wall roughness model with all dimensions set to 0 m).
This answers my first question, but my second question still remains, which is:
Who can I make CFX capture a particle, when the distance between particle centre and collecting surface is less than the particle's radius? Would I need to implement my own algorithm using a CEL? How would I do that? How would I start?
Also see this tread
solver: CFX 13.0
Old   November 16, 2011, 18:48
As I said in your other thread, I do not think this can be done in CEL. You may be able to implement it in user fortran. Also have a look at the particle collision model in CFX, you may be able to adapt it to wall collisions also.
Old   November 17, 2011, 07:38
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
Please can you explain in more detail your work. You said you are using "stick to thw wall", so I think ytou are using a transiente model and you are calculating energy, right?
If not, you can just use the restitution coeffcient and thatīs it..
You can upload the .out file. There you will find several information about your problem.
juliom is offline   Reply With Quote
Old   November 17, 2011, 09:27
Julian Krick
I try to get in contact with Ansys and ask for advice. All I would need to do is to write an algorithem which calculates the distance between the cylinder's centre and the particle's centre. However, I have no experience with user fortran. Are there tutorials which explain what to do?
solver: CFX 13.0
Old   November 17, 2011, 16:01
Calculating that distance is not trivial - how do you find the closest wall? how do you calculate the normal distance?
User fortran is not thoroughly documented and few examples exist. ANSYS does run training courses on it. There is also some experience with user fortran on the forum (but not me, I have rarely used it).
Julian K. likes this.
Old   November 17, 2011, 16:25
Julian Krick
I am simulating particle flow over a 2D circular cylinder. So I have the centre coordinates of the cylinder and the centre coordinates of the particle.
I will look into that. Thank you for the hints!
solver: CFX 13.0
Old   November 17, 2011, 16:36
If you can describe your wall analytically then it should be quite simple. But if you had to extract this from the mesh this would be a challenge.
Old   November 17, 2011, 16:49
Julian Krick
I can describe the wall analytically. That's not the problem. For me it's more challenging to implement the algorithem with a user Fortran.
solver: CFX 13.0
Old   November 18, 2011, 12:08
Julian Krick
I opened a new thread for my problem: here
solver: CFX 13.0
Old   January 12, 2012, 09:49
Julian Krick
I found a way to solve my problem using a User Fortran. I posted the solution here.
solver: CFX 13.0
cylinder, impaction, lagrangian, particle, stick-to-wall
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
Set a maximum particle number on a surface injection benjamin16 FLUENT 2 January 19, 2016 00:35
Multiple surface particle injections from the command line mbeals FLUENT 0 June 3, 2009 14:11
Can -FLUENT solve non-coal particle surface reacti Ganesh kumar FLUENT 0 February 20, 2006 02:03
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 06:27
