Translate the pressure field on a cylinder side to a plane |
Darren Zhang
Rep Power: 14 ![]() |
The Geometry of the model is similar with a cylinder,and I get the pressure field on the side surface of the cylinder .For easier to analyse the 360 degree pressure field on the side ,how to make the pressure field be visual on a plane surface in CFX,or other Code(such as Tecplot)?
Thank you for your answer in advance! |
Darren Zhang
how to do this?
Anyone can give an idea? |
Rep Power: 143 ![]() ![]() ![]() ![]() |
I do not think you can do this in CFD-Post. But you can do most of the hard work by defining a variable theta which is the angle around the body, and exporting theta, z and you variable to a file. You can then load it in anything (matlab, excel if you must or any other plotting program) and plot it as a 2D plot of theta versus z.
Not possible in CFD-Post
http://www.ilight.com/fieldview12.3_whatsnew.pdf. Here you will find the feature known as unrolled cylindrical surfaces. |
Bruno
Rep Power: 21 ![]() |
Well,
If we're talking straight about surfaces of revolution than it might be possible to unwrap them using Turbo Post. The down side is that you have to find equivalents for the turbo closed region (inlet, outlet, hub, shroud). The up side is that if you don't have such regions you can provide Post with lines that represents them. These lines can be generated using polylines, for example. If anyone claims this is not straightforward, I would totally agree. But if you don't have any other tool, than at least you have a way of plotting your data the way you want. Cheers |
#7 | |
Darren Zhang
Thank you very much for every method.
I will try. |
How to read pressure at discrete points | paka | OpenFOAM | 16 | April 28, 2020 07:26 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
order of magnitude analysis | atit koonsrisuk | Main CFD Forum | 3 | July 27, 2000 11:59 |
Using SIMPLE | david | Main CFD Forum | 5 | July 21, 1999 02:38 |
