CFX-11 vs CFX-13 SST Model
Old   November 30, 2011, 05:13
Default CFX-11 vs CFX-13 SST Model
Zigainer is on a distinguished road
Hey,
I'm simulating a two-pass-channel with rectangular geometry.
I've got some previous results with CFX-11 and SST Model. The previous simulation (done by a other person) compares different turbulence models for the same geometry. My CFX-13 results (also done with SST model) are different.
So does anybody know, what ANSYS changed in there turbulence models?
It kind of looks like the CFX-13 SST model uses some elements from CFX-11 SST cc model.
Hope you guys know a little bit more.
Zigainer is offline   Reply With Quote
Old   December 1, 2011, 12:26
Far
Sijal
Well, I dont see any change in SST model
Old   December 1, 2011, 16:48
I suspect there have been some small changes in a few of the peripheral models (eg streamline curvature) and the numerics could be different. You would have to either troll through the release notes or contact CFX support to be sure.
Old   December 1, 2011, 17:04
Far
Sijal
I ran few cases on CFX 12 and 13 with SST model and same settings (e.g. same mesh, boundary conditions etc) and I didn't find any difference
Old   December 1, 2011, 23:46
For almost all cases you won't find a difference. It is only on rare cases that you will find a difference.
Old   December 2, 2011, 01:42
Far
Sijal
I would suggest to compare each and every term and constant factor in CFX theory guide of V 12 and 13
Old   December 2, 2011, 02:18
Thanks guys. I compared the factor in theory guide and there are all the same. I was just wondering about my results (compared to a old study done by a stundent in 2010)
Old   December 2, 2011, 04:06
Far
Sijal
Mesh and other settings are same in your study and old resutls?
Old   December 2, 2011, 04:14
Not quite the same (I don't habe the old mesh). Problem is, that I am doing a conjugated calculation for a ribbed cooling-channel. The older thesis did only simulate the fluid with constant wall-temperature. My results are not very close to the experiment (different contour). The old thesis (turbulence model study) has almost the same contour with SST. But the old SST cc looks quite the same as my SST. And in the end my results for heat transfer are too good (Nu/Nu_0 is almost constantly 0.5 above experiment).
Old   December 2, 2011, 04:33
Far
Sijal
SST and SST-CC model are same except in some flow regions where CC model is activated (some triggering factor in production term). Therefore if your problem does not have that sort of region of flow then SST and SST-CC shall behave identically.
Old   December 2, 2011, 04:40
Thanks for your help. I probalbly have some of these regions because my channel is ribbed.
So I startet a SST-cc calculation, and then I'll see if there is a difference in CFX-13.
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Missing Information in SST Transition Model Formulation Josh CFX 2 September 14, 2010 11:49
Turbulence model for CFX moving mesh songxguan CFX 7 June 28, 2009 21:05
Implementation details of SST k-omega model Niels Main CFD Forum 3 July 3, 2008 17:45
