February 29, 2012, 12:03 |
overflow problem
albert
Rep Power: 14 |
Hi, while solving a flow trough a porous media (no perm, no Res.loss coefficient), the solver stopped, saying an overflow problem had occured. As boundary conditions i have velocity of the inlet flow and presssure in the opening, which i guess are the most robust boundary conditions to get convergence. On monitor points the velocity of one of the points reached amazing high values, which is obviously wrong.
With normal fluid media and same boundary conditions it worked perfectly! is there anything strange i should know about porous media?? here the solver data OUTER LOOP ITERATION = 49 CPU SECONDS = 7.755E+03 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 1.62 | 2.6E-03 | 2.0E-01 | 2.2E-01 ok| | V-Mom | 1.10 | 2.6E-03 | 1.7E-01 | 1.7E-01 ok| | W-Mom | 1.43 | 3.9E-04 | 3.2E-02 | 2.3E-01 ok| | P-Mass | 1.10 | 3.2E-04 | 5.6E-02 | 8.6 4.1E-01 ok| +----------------------+------+---------+---------+------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine C_FPX_HANDLER: | | | | Could someone help me tpo solve the problem?? |
February 29, 2012, 17:17 |
Rep Power: 143 |
Do a search on the forum for floating point error. Been asked thousands of times.
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
overflow problem | bruno | CFX | 2 | November 26, 2006 16:28 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
