Selection of time step
Old   March 14, 2012, 09:29
Arrow Selection of time step
Georgia Papa
Giorgitseli is on a distinguished road
Hello everybody.
I am new user regarding the transient calculations and I would appreciate any useful information about how I can select an appropriate time step for my simulation.
Moreover does anybody know if I can "insert" in CFX a steady state flow field and then run a model for the solids that exist in the fluid domain???I hope that if this is an available option in CFX I could reduce the required total computational time. Regarding the particles I use the algebraic slip model (no deposition).
THANX
Giorgitseli is offline   Reply With Quote
Old   March 14, 2012, 16:28
By solids I assume you mean ASM of small solid particles.
Yes, you can do this, but the whole idea of ASM is it couples back to the flow. You can turn bits of the solver off with expert parameters, so you can turn off the pressure/momentum equation but solve the ASM equations. Alternately using particle tracking you could do this as a one-way coupled simulation.
ghorrocks is online now   Reply With Quote
Old   March 15, 2012, 06:03
Georgia Papa
"You can turn bits of the solver off with expert parameters, so you can turn off the pressure/momentum equation but solve the ASM equations. Alternately using particle tracking you could do this as a one-way coupled simulation."
Thanx for the rapid answer!
1.)How can I turn off the pressure/momentum equation and only solve the ASM equations??I ll check the particle tracking method because I have not yet worked with this!
2.)Any idea for the time step selection?
Old   March 15, 2012, 15:05
Javier Climent Agustina
CFD_UJI is on a distinguished road
hi! from what i know, you have to select a time step so that the Courant number of your problem is approximately 1. thanx
Daniel
CFD_UJI is offline   Reply With Quote
Old   March 15, 2012, 15:22
Zigainer is on a distinguished road
ghorrocks already answered your first question:
Zigainer is offline   Reply With Quote
Old   March 15, 2012, 16:47
This one keeps coming up, it is wrong.
CFX is an implicit solver and does not have the CFL<1 (compressible) or Courant No<1 restriction. You should determine time step size by a sensitivity analysis, and you will probably end up with an acceptible time step size larger than 1.
This restriction applies to explicit solvers.
time step, transient
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
time step selection Jackie Main CFD Forum 5 January 12, 2004 12:26
VOF özgür FLUENT 8 January 6, 2004 08:23
