March 26, 2012, 16:48 |
Is there a limit for CEL expression length?
Hello.
In my model, I use a rather long CEL expression for temperature. It should be a periodic function with not very trivial shape, and I want to avoid user subroutines in fortran. I tried to specify the shape using CEL and with if-expressions. However, I get an error message (something with "exceeds normal size", can't tell off of my head). If I remove a part of the expression, everything works OK. If I add a piece again, I get the error message. I've checked the syntax several times and think that there is no syntax errors. Hence I suspect that I hit some limit of the CEL expression length. Is there such limit? If yes, what is the value? Any help will be much appreciated! |
March 26, 2012, 17:54 |
Rep Power: 143 |
I am not sure whether it is a length restriction or a complexity restriction (ie how many functions an expression has), but I am sure there is a restriction.
In that case split the CEL expression into several variables to simplify the expression. |
March 27, 2012, 02:20 |
Lance
Rep Power: 22 |
Yep, there's a limit. Cant remember the exact limit, but one of my expressions had about 30 nested if-statements which worked. If you need the exact limit I suggest you contact Ansys.
cel expression, maximum length |
Problem About Running Fluent In Linux | mitra | FLUENT | 18 | June 20, 2019 02:11 |
Turbulence length scale and integral length scale | rizhang | CFX | 2 | April 22, 2016 07:22 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
