Running CFX and Structural Analysis Separately
Old   April 12, 2012, 23:00
Question Running CFX and Structural Analysis Separately
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear All,
I am modelling FSI in a pipe using Ansys CFX. What I want to do is to run the fluid part first and get time dependent average pressure on the wall. Then use this pressure distribution in structural part to find out how big the wall deformation is.
I am OK with fluid part; however, don't know how to apply the fluid pressure in structural part. Does anyone know how?
Kind regards,
AshtonJ
ashtonJ is offline   Reply With Quote
Old   April 13, 2012, 16:03
Roger Yang
rogeryang is on a distinguished road
You need to import the pressures from CFD into Structural model. Check out the Probe Tutorial in ANSYS Customer Portal area.
rogeryang is offline   Reply With Quote
Old   April 13, 2012, 16:48
stumpy is on a distinguished road
Since the case is transient I wouldn't recommend the approach used in the probe tutorial. Using the 2-way/MFX approach, but only sending data in one direction is the first choice. The other option is to use APDL commands to read in the transient loads. I would ask ANSYS support how to do that.
stumpy is offline   Reply With Quote
Old   April 14, 2012, 01:21
Ashkan Javadzadegan
Thanks for your helps.
I went through the probe tutorial. As Stumpy said, in this tutorial, a constant pressure load is transferred not transient!
Dear Stumpy, could you please explain a bit more about your recommended options:
2-way/MFX and APDL commands.
Thank you all
Regards,
AshtonJ
Import transient cfx-results for static structural analysis in Ansys WB 13 Colt Seavers ANSYS 1 August 11, 2011 06:01
Transfer from CFX to Static Structural student82 CFX 1 March 2, 2011 04:17
CFX to Static Structural sberez CFX 1 October 20, 2009 08:59
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 14:26
Structural and Aerodynamic Analysis Márcio Lima Main CFD Forum 3 April 20, 2008 12:14
