simulating wind shear profile for a wind turbine--> How???
Like Tree1Likes
  • 1 Post By mohammad
Old   April 14, 2012, 22:00
Default simulating wind shear profile for a wind turbine--> How???
mohammad
mohammad is on a distinguished road
Hi everybody
I am doing a CFD simulation of a 2 bladed wind turbine under wind shear profile condition when the wind speed changes according to a logarithmic wind profile. The wind turbine is standstill ( not rotating) and I want to model a single blade at the zero azimuth angle ( = blades are supposed to be vertical).
The question is:
How should I simulate the B.C on the geometrical plane of symmetry?
What is the B.C? From the first moment it is clear that "Symmetric" boundary condition is not true because the wind speed distribution on the two sides of this plate are not the same.
I was thinking to use a domain and put a single blade somewhere in the domain. in this new model the domain is stretched out of both sides of the blade ( form the root and the tip).Therefore I can apply the wind profile to the domain and this wind profile contains some part of the wind profile just before the blade's root. ( SEE THE ATTACHMENT )
This new idea can simulate some effects of wind shear profile near the blade's root; however, because the other blade does not exist here the wind simulation is still not exact in the sense that the wind before the blade's root is not affected by the other blade.
Can anybody please help me to clarify which B.C should I use?
Regards,
jam_ktc likes this.
mohammad is offline   Reply With Quote
Old   April 15, 2012, 18:13
It is not clear what you are modelling. If this is modelling the blade when stationary then apply a tangential velocity equal to the velocity at your boundary.
Old   April 15, 2012, 21:25
mohammad
Dear Glenn
because I am going to simulate half model( one blade only) , I am asking about the B.C. of the plane of geometrical symmetry which passes through the hub and divides the wind turbine to two geometrically similar blades.
According to your idea, if i apply this condition, still i am removing the effects( shear effects) of the removed part of model ( the other blade) which is not simulated in my simulation.
my question is that is there any way to simulate the effects of the wind shear ( friction and shear forces,....) on that plane?
Regards,
Old   April 17, 2012, 01:10
Why not model this using the rotating frames of reference? Then you can do a model with the difficulty of a steady state simulation, but include the effects of blade rotation. Much more accurate and easier. Also you do not have the weird bottom boundary to worry about.
Old   April 17, 2012, 01:14
mohammad
I am doing the standstill analysis....How can I use the rotary frame for a stationary case!!!???
Old   April 26, 2012, 20:01
mohammad
Hi everybody!!!!
Any help???!!!
Old   April 26, 2012, 21:13
Yes, as I said before just apply a tangential velocity to the plane equal to the boundary layer velocity at that height.
Old   October 9, 2012, 05:20
Smile
mohammad
Originally Posted by mohammad View Post
Hi everybody
I am doing a CFD simulation of a 2 bladed wind turbine under wind shear profile condition when the wind speed changes according to a logarithmic wind profile. The wind turbine is standstill ( not rotating) ...........................................
Regards,
Dear all,
I have made the model and applied the velocity profile ,as mentioned by Glenn Horrocks.
However I cannot get a stable results.
I have tried many differnt timesteps.....also I switched to the Transient simulation . But, all of my attemps failed.
Do you have any idea? how should I get the results....
Thanks,
Old   October 9, 2012, 06:28
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Old   May 28, 2013, 11:07
s.q
s.q is on a distinguished road
Dear all,
Thanks,
hi mohammad
i had simulated a wind turbine in fluent such as you.
and now i want to calculate the output power using torque(report-forces-moment)
but this output power is 10 times bigger than real amount.
would you plz guide me????
s.q is offline   Reply With Quote
Old   May 28, 2013, 11:16
mohammad
Originally Posted by s.q View Post
hi mohammad
unfortunately the commercial CFD softwares are always erroneous. First make sure about your Turbu. model.
Then, check your grid resolution for a) adequate nodes in different areas including chordwise, spanwise and near wake zone.
Later check your y+ and # nodes inside the BL.
at last check the convergence.
good luck
Old   May 28, 2013, 21:43
Rubbish. If they are always wrong then why do people buy them? Used properly it is accurate for many cases.
The issue is almost certainly a problem in the way the simulation was set up, not the software itself.
Anyway, this vague question is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   May 28, 2013, 23:59
mohammad
Rubbish !!!!!! .
First of all ghorrocks, I am sure that you do not need to become angry like this. This is a public forum, so please watch your words and be formal.... Knowlege is the best thing if comes with politness. I AM SURE politness BRINGS YOU MORE CREDIT.
[/QUOTE]
No doubt about ghorrocks' experience and knowledge, however, as all turbulence models are , to some extent, based on some theoritical and even hypothetical formulations, how could you stand on the CFD softwares' side and support them like this? If they are as exact as you say, why do scholars try for the improvement?????
Old   May 29, 2013, 00:21
I apologise if my frankness offends you but I tend to get straight to the point By the way, I am not angry.
Yes, turbulence models are based on theoretical, empirical and even guessed models. But if they give you results which are accurate enough to improve your design that is all which matters. The key phrase is "accurate enough". I wish the scholars all best in their quest to make CFD more accurate and able to handle a wider range of applications, but software available now is adequate for most purposes.
Old   August 25, 2014, 09:09
Question How to set shear inflow velocity type of inlet boundary condition in openfoam?
  #15
Fengjiao Bian
jiaojiao is on a distinguished road
as this said to use the tangential velocity,but I dont know which patchfield I should use.could anyone tell me?
I forget where I have ever seen the set that
[ inlet
{ type shearVelocity;
n (0 0 1); direction
y (0 1 0); vertical aixs
value 7; the velocity value
]but it is wrong when I try it,it shows that unkown patchfield type shearVelocity.I am waiting for your help!thanks so much!
jiaojiao is offline   Reply With Quote
wind shear profile
please help in simulating a wind turbine blade in 6 DOF ????.... usman naseer Main CFD Forum 2 March 10, 2016 02:53
Does anyone have 3D blade profile of wind turbine? kenya0514 Main CFD Forum 5 March 9, 2015 14:06
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
Simulate the wind profile on a wind turbine---> HOW ???? mohammad Main CFD Forum 0 April 13, 2012 08:07
Simulating a wind turbine test in Solidworks Dodger Main CFD Forum 0 March 4, 2011 06:34
