Home > Forums > Software User Forums > COMSOL
Waves halted by moving mesh
Old   November 23, 2007, 12:23
Default Waves halted by moving mesh
Piotr Czajko
Fellows,
My 3D numerical wave tank (built in COMSOL) doesn't work right, hopefully someone here can shed some light.
first question, Q: can anyone point me to a good source for the proper moving mesh displacement/velocity components in terms of fluid velocities?
The imposed moving mesh (on the 'free-surface') does not show waves propagating down the tank but they remain trapped (in time) within the first row of mesh elements.
/\_________ --> wave direction | | | | ------------
I have a gravity force on the domain, non-slip conditions on the end, bottom and side wall and a velocity profile on the left hand side straight from linear wave theory.
2^nd Q: Has anyone observed this? 3^rd Q: Why would a moving mesh be so stiff? 4^th Q: Does anyone have a better way?
Alot of questions, yes. Thanks for any help you can offer!
Piotr
Old   November 24, 2007, 02:00
Default Re: Waves halted by moving mesh
momentum_waves
Have you perhaps created a 'numeric' shock in the first cells? Your boundary/conditions may/or may not, actually be predicting a shock & locking your wave in that position.
Some solvers can cause this problem with wave-based simulations. Try changing your solver type, & reduce element dimension. Also, make sure you have the correct time-step to capture the wave flow.
mw...
<www.adthermtech.com/wordpress3>
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
