Modify Chlorine global model in COMSOL library to high pressure regime |
Chiah Zi Jing
Location: Xiamen University Malaysia (XMUM) Sepang, Malaysia
Rep Power: 2 ![]() |
I am currently modifying the chlorine global model in COMSOL application library which designed to be work under low pressure to atmospheric pressure range. In the variable section I noticed that the gas temperature is a function of both power and pressure. However, I am not sure how to modify this equation for atmospheric pressure case. Here is the paper for the model: https://sci-hub.ru/10.1088/0963-0252/19/1/015001 and here is the equations mentioned which relate the gas temperature with power and pressure:Attachment 98130 Last edited by tomchiah; January 15, 2024 at 15:34. Reason: I attached the wrong picture, kindly refer to the attached thumbnails below |
equation formulate, modify equation, modifying model, plasma modeling, pressure change |
[IHFOAM] The IHFOAM Thread | Phicau | OpenFOAM Community Contributions | 392 | September 8, 2023 18:10 |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca | insane | OpenFOAM Running, Solving & CFD | 0 | May 17, 2020 22:35 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
