January 17, 2017, 10:28 |
Spark plug
Hiren Tala
Rep Power: 9 |
hello, i am starter in Converge Software learning. and Student in the Univeristy. i am simulationg single cylinder Spark ignition engine. I want to know, weather i can choose coordinates inspite of Spart plug geometry? in my model, their is no spark-plug geometry just a simple closed cylinder head Body in my model. if i design spark plug in 3D modelling, then i can not assemble it directly in converge , i have to replace whole Modell. can i choose just like coordinate or something, so i can give their high energy accordingly perticular crack Timing. so i dont Need spark plug geometry then, is it possible? please let me know how ?
January 19, 2017, 15:00 |
Jerome Le Moine
Rep Power: 10 |
Spark plugs are modeled with a source of energy, the geometry of the spark plug helps to get a better representation of the flow in that area. The geometry of the spark plug does not need to present in the geometry to model a SI engine. For reference, I will recommend reading the theory manual chapter 19.6 which talks about the energy sources in engine models. In addition, you could download our example cases to see how the source is set up in a real case.
January 21, 2017, 09:46 |
Tobias
Rep Power: 11 |
Its actually quite easy to implement the geometry into your case.
If you dont have a spurk plug geometry, take the one from the example case. a) Open the case and delete all other boundaries, then export surface.dat b) Go to your case and import this surface.dat c) Create the boundary and assign these cells to it. Then translate the Sparkplug to the desired postion. d) Delete cells from your cylinder head boundary and create new ones, either one-by-one (3 vertices) or from open edge to open edge to connect the Spark plug with your head geometry. e) Check the normals and you´re done |
January 24, 2017, 04:02 |
Tobias
Rep Power: 11 |
Small addition:
The tutorial cases have wall temperatures of 550K and 600K (electrode). However, i found information of NGK: https://www.ngk.de/en/technology-in-...rature-window/ So they propably get a lot hotter (mean is 650°C = 923K). The same can be said about the exhaust valves. |
February 28, 2017, 06:00 |
Hiren Tala
Rep Power: 9 |
thanks for your answers.... I was busy since a month in University exams, so couldn't thank.
How to define spark plug for combustion | pradeep6890 | STAR-CD | 17 | September 12, 2016 05:01 |
Valve,spark plug cell allotment-prostar | pradeep6890 | STAR-CD | 0 | March 18, 2016 00:38 |
Combustion in Spark Ignition Cylinder | tom634 | FLUENT | 1 | December 30, 2014 11:45 |
Liquid plug using interFoam | praveensrikanth91 | OpenFOAM Pre-Processing | 1 | February 16, 2014 02:00 |
Spark ignition | lost.identity | STAR-CD | 0 | February 4, 2013 08:32 |
