May 11, 2018, 00:03 |
mass flow
liyong
Rep Power: 9 |
In my case, I set a inflow boundary for injecting hydrogen. The boundary type I choose is mass flow, and the profile as attachment(mass_flow.png) shows.
In the result of mass_avg_flow is showed in attachment(mass_flow_rate.png), and it looks normal, but the total mass of hydrogen in species_mass.out is wrong. I caculated the mass of hydrogen if it is injected by the profile, theoretically,it should be 4.6mg. However, the result from CONVERGE is 4.1mg(mass_H2.png), and the error is 10.9%. It's abnormal, but I don't know why? The follow is caculation procese: engine speed=1500rpm, so crank angle speed is 1500*360/60=9000CA/s massflow is 2235.98mg/s, equally 2235.98/9000=0.2484mg/CA so total mass:0.2484*(17.5+19.5)/2=4.6mg |
May 14, 2018, 16:32 |
Shengbai Xie
Rep Power: 9 |
May I know if it is a closed system, please? If you have outflow or backflow at the inflow, then the mass of H2 in the domain may not be the same as you injected. Also, may I know why it is 0.2484*(17.5+19.5)/2 rather than 0.2484*17.5=4.37mg, please? If it is a closed system and the mass is not conserved, then we have to take a look at your case setup to determine why it is. Please send an inquiry to support@convergecfd.com. Thank you. |
May 14, 2018, 21:38 |
liyong
Rep Power: 9 |
Because the injection profile is trapezoidal, so it's area is (a+b)/2*h
There is no outflow or backflow boundary. I have sent the case to support@convergecfd.com. Thank you. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Define mass flow profile with regards to species mass fraction | danS | Fluent UDF and Scheme Programming | 0 | June 20, 2017 06:21 |
Mass flow rate boundary condition with negative values | ashtonJ | CFX | 3 | November 26, 2014 05:21 |
mass flow | Wenbin Song | FLUENT | 0 | September 27, 2005 13:00 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 19, 2003 14:03 |
