January 8, 2019, 12:20 |
Significance of passives
mohsin
Rep Power: 7 |
What is the difference between passive boundary condition (boundary condition) and passive section(regions and initialisation) ?
January 8, 2019, 16:44 |
#2 | |
John Etcheverry
Rep Power: 7 |
Transport passives work very similar to any other variable that is being transported. They require a boundary condition and an initial condition to find a unique solution. For example - think of a dye tracer. If I wanted to trace where the flow from the intake region and boundary of a 4-stroke engine I could "dye" the flow from that region and boundary with an passive (call it INTAKE). I would initialize the intake region with that passive equal to 1 and have the corresponding inflow boundary also have the INTAKE passive set to 1. That way any flow entering the intake region keeps the INTAKE passive and all mass in the INTAKE region initially is "dyed" with the INTAKE passive to start. Let me know if I can be of further assistance! Thanks, - John |
January 9, 2019, 12:17 |
#3 | |
mohsin
Rep Power: 7 |
January 10, 2019, 10:33 |
#4 | |
John Etcheverry
Rep Power: 7 |
Unless you expect there to be some inital value of NOX or soot in the region of interest it is not necessary to give NOX or HIROY_soot a non-zero value. If you are mapping from a previous run those passives will be set by the the map file. I recommend taking a look at the following two example cases in Studio to help with what it appears you are trying to do: - Tumble_GDI_SAGE - HSDI_Diesel_engine_with_induction Thanks! - John |
January 10, 2019, 11:17 |
#5 | |
mohsin
Rep Power: 7 |
January 10, 2019, 11:21 |
John Etcheverry
Rep Power: 7 |
January 10, 2019, 15:06 |
mohsin
Rep Power: 7 |
January 14, 2019, 09:38 |
#8 | |
John Etcheverry
Rep Power: 7 |
It is a recommended practice but is not necessary unless you are using some of the built in calculations within CONVERGE. For example - a multi-cylinder simulation will not have all cylinders centered on the global coordinate system. Thanks, - John |
Significance of brackets [] in boundary.in | Pndsc | CONVERGE | 3 | January 16, 2019 18:03 |
physical significance of.... | vijesh | Main CFD Forum | 7 | August 13, 2007 03:18 |
Significance Y-Plus and Y-Star | Jonathan | Main CFD Forum | 3 | January 17, 2007 08:58 |
Stream Function physical significance? | ram | Main CFD Forum | 0 | February 21, 2001 08:45 |
Significance of damkohler number | Pargaonkar Vijay | Main CFD Forum | 2 | May 4, 1999 13:41 |
