there are duplicated species in the species list |
May 25, 2019, 11:38 |
Rep Power: 7 |
Hi
what would be the cause of the below error? I am trying to simulate liquid N2 flowing into gaseous N2 environment. reading inputs.in data from file inputs.in turbulence_solver_flag = 1 in inputs.in, reading in turbulence.in reading turbulence.in data from file turbulence.in reading solver.in data from file solver.in reading mech.dat data from file mech.dat reading species.in data from file species.in species with N2 is duplicated reading therm.dat data from file therm.dat there are 0 reactions and 2 species reading initialize.in data from file initialize.in reading vof.in data from file vof.in reading liquid.dat data from file liquid.dat WARNING: Generic "NON_NEWTONIAN" liquid parameters given in liquid.dat, assuming "HERSCHEL_BULKLEY_MODEL" parameters given. reading transport.dat data from file transport.dat transport data found for all the species creating diffusion coefficient(Dij) tables... diffusion coefficient tables calculated. JOB ABORT invoked by rank 0: 1550 ERROR: there are duplicated species in the species list |
May 29, 2019, 11:11 |
Rep Power: 10 |
Seems like you might be defining the liquid and gaseous N2 by the same name. Could you try renaming the liquid N2 to N2_L/N2_Liquid in liquid.dat and all other places wherever you are using this liquid? Thanks, |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
