Home > Forums > Software User Forums > CONVERGE
Nonmanifold Problem
Old   December 29, 2020, 01:41
Default Nonmanifold Problem
Asher
mohmdasher is on a distinguished road
I'm trying to simulate conjugate heat transfer in a pipe flow, two concentric cylinders are made such that the annulus forms the pipe wall thickness and the inner cylinder is where the fluid flow occurs.
After creating the two concentric cylinders, I close the top and bottom faces of the cylinder using repair--->patch option, I create a patch for the annulus and a different patch for the inner cylinder (ref. attachment). The two patches I create lead to nonmanifold error which I'm unable to resolve without deleting the patches. The. cvg file is also attached as .txt can be renamed back to .cvg.
mohmdasher is offline   Reply With Quote
Old   December 29, 2020, 12:22
SamWijey's Avatar
Sameera Wijeyakulasuriya
SamWijey is on a distinguished road
Non-manifold errors are fine for CHT cases as long as those surfaces are specified as interface boundaries. Please refer to our CHT training slides (downloadable through our website) and the CHT example cases in CONVERGE Studio.
Principal Engineer, Applications
CONVERGECFD
SamWijey is offline   Reply With Quote
converge cfd, convergence check, nonmanifold errorr
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
