May 8, 2014, 10:09 |
Maxwell electromagnetics amps-turn question
Hi guys,
Quick question on setting the excitation current on an ansys Maxwell electromagnetics analysis: I have a coil which has 1500 turns with 15 amps flowing through it. Do I set the excitation current as 22500 amps in the current excitation or will I create a single coil terminal with 1500 conductors and specify the inital current as 15A when specifying a winding to the coil terminal. Aplogies if im missing something obvious here, first time using Maxwell. Thanks in advance, Paul |
May 9, 2014, 10:12 |
Just as an update, ran the model at 22500 amp-turns and the results are 3 times higher than measured results on a real life setup. From further reading I can see specifying inital current and defining windings etc. Relates to transient magnet analysis. So what i have dobe above is what the ansys guide recommends.
Now to find out why the results are so high... Really losing faith in FEA systems! :/ |
May 24, 2016, 02:34 |
srijan.rio
Rep Power: 10 |
Hello. I have to design a coil having 120 AT and 60 turns. I intend to do transient simulation. I have a confusion regarding whether shall I use the no of conductors in the current excitation as 60 and the current magnitude in winding as 2A or 120 A ? If you could kindly guide me it would be really helpful
ansys maxwell amps turns |
