Home > Forums > Software User Forums > Fidelity CFD
negative efficiency
Old   May 22, 2012, 10:07
Default negative efficiency
sajad
sajad is on a distinguished road
hello everyone
I am reading "Fine turbo tutorial guide"
I've done the example for Hydraulic turbine-Francis , every thing is ok but the result for efficiency is negative value
I set the rotation speed= -500.0 as said in the tutorial
these are the results in the ".mf" file under "global performance" part :
Static_pressure_rise -56981.
Absolute_total_pressure_rise -55488.
Static_Head -5.8027 [m]
Absolute_total_Head -5.6506 [m]
Static_temperature_rise 0.53888E-02
Absolute_total_temperature_rise 0.57514E-02
Efficiency -0.86326 (based on total pressure rise and power)
Axial_thrust -11945. [N]
Torque -329.92 [N m]
Power 17275. [w]
I think the problem is in the definition that it uses for computing efficiency , but i don't know how to correct it
could anyone help me?
thanks
sajad is offline   Reply With Quote
efficiency, fine turbo, francis turbine
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
