January 7, 2014, 07:37 |
Hexpress: failed feature line recognition
Tim Franke
I came across a phenomena and I wonder if someone could tell a work around. Given a cube where one edge is not completely sharp since after half of the edge length the sharp edge runs over into a radius that increases from R=0 to R=max at the corner point. After importing as stl eleven edges a shown a feature lines but the single edge decribed above is absent, although I would expect to see a feature edge that covers half of the cube edge. From a feature angle point of view the featre edge should be there. Regards, Tim |
January 7, 2014, 09:28 |
Onno
A picture would help understand the problem.
But I don't know if a feature edge can just stop, without connecting to other edges. Do you have to use STLs? |
January 7, 2014, 10:52 |
Tim Franke
Just imagine a cube where one edge radius develops from being 0 (sharp)
to a finite value (round). In Hexpress the whole edge is not marked as a feature line although the first part is perfectly sharp. If I read in stl the only way to detect feature lines is to evaluate the angle of surface normals between neigbouring cells. If that angle exceeds a given threshold then the common edge is a feature line. Obviously this is treated differently in Hexpress leading to the described deficit. Importing the geometry as Parasolid leads to the same failure. Regards, Tim |
January 7, 2014, 12:44 |
Onno
How about splitting the cube at the point where the edge starts getting rounded?
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
