May 6, 2014, 09:32 |
Meshing problem
Amirah
Rep Power: 12 |
May someone help me. I import a STL file into HEXPRESS. After create a domain in the STL Manipulation, this statement are emerge.. **Warning: Critical problems have been detected with the domain **Domain check: Edges with sharp angles - edge 1 Then I continued with Automation Edge Merge and Automation Face Merge in the Domain Manipulation. However, my Mesh Wizard still unable to use. How I want to solved this problem in order to able doing the mesh? Thank you. |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 07:04 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
