Home > Forums > Software User Forums > Fidelity CFD
Fine/Turbo cannot open grid built by IGG, Configuration file problem?
Prev Previous Post   Next Post Next
Old   March 11, 2016, 02:42
Default Fine/Turbo cannot open grid built by IGG, Configuration file problem?
Jessica Wei
wkjshon is on a distinguished road
Dear all,
A tricky problem...
I'm using Fine/Turbo 10.1 now. There's a problem that makes me really confusing.
When I used the file that was built by Autogrid as the grid file for the Fine/Turbo case, everything was fine.
However, when I used the file that was built by IGG as the grid file for the Fine/Turbo case, the grid couldn't be recognized and there was a warning said "The grid configuration file does not contain all the blocks defined in the mesh file."
I've checked the configuration file, and found nothing wrong.
I tried to build a new igg file that only contains one single block. But the the same error occured.
I also tried an older version Fine 9.13. Still the same error.
I have to use IGG to generate the Volute Mesh of the Compressor. But the Fine/Turbo cannot open the grid!
Did someone have the similar problem? Please help me......
Desperate.....
Thanks in advance,
Jessica
wkjshon is offline   Reply With Quote
fine/turbo, igg
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
