Home > Forums > Software User Forums > Fidelity CFD
Changement of Grid Units
Old   June 27, 2016, 09:09
Default Changement of Grid Units
Matthias Av is on a distinguished road
Hi all,
I would like to change the grid unit of my computation (meters to millimeters) without opening the FINE interface (because of bug).
I thought open .run file linked (to my computation) but I don't know what is the correct parameter to change.
Does anyone have already do this manipulation?
Thanks in advance.
Matthias.
Matthias Av is offline   Reply With Quote
Old   June 27, 2016, 15:39
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
Dear Matthias,
Unfortunately I cannot test it at the moment, but I think I found the parameter in the .iec project file. Please search for
#******* START GRID PARAMETERS SECTION **************
NI_BEGIN grid_bc
VERSION 1.0
GRIDUNIT 1
NUMBER_OF_GRID_LEVEL_I 2
NUMBER_OF_GRID_LEVEL_J 2
NUMBER_OF_GRID_LEVEL_K 2
IGGGRIDVERSION 5
SHOWAG5MESSAGE 0
I assume GRIDUNIT=1 is the scale factor relative to the unit [m], which means this example mesh has the grid unit [m]. If you want to set it to [mm] the parameter should be changed to GRIDUNIT=0.001 for example.
DarylMusashi is offline   Reply With Quote
Old   June 28, 2016, 02:17
Thanks for the answer that's working
Fluent LES model: grid requirement? dinhanh FLUENT 1 November 11, 2015 12:15
How to make grid for LES simulation dinhanh Main CFD Forum 3 November 11, 2015 02:37
Grid Adaptation Suresh FLUENT 0 October 15, 2003 13:18
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 22:26
