Home > Forums > Software User Forums > Fidelity CFD
NUMECA Problem about Parallel Partitioned Computation
Prev Previous Post   Next Post Next
Old   October 13, 2019, 11:03
Default NUMECA Problem about Parallel Partitioned Computation
gaolingtao
Gone is on a distinguished road
I have a grid with H-O-H topology on B2B section, and it has three blocks. At first, i used parallel computation in FINE/TURBO, it is ok and I could get results. But it is too slow considering I could use three processes at most. So when I choosed parallel partitioned computation, it appeared "run time error" sometimes and sometimes it worked well.
And the .std file shows below:
check_feature 'Solver'
checking regular version
STARTING NUMECA FLOW SOLVER
Broadcasting the runfile
Building the project from broadcasted data
...done in 0-sec (Building the project from broadcasted data)
...done in 0-sec (Broadcasting the runfile)
Running the partitioning...
Assembling the initial block decomposition from the FINE topology...
...done in 0-sec (3 blocks found)
Virtualizing the patches
The following patches have not been connected: 1 INL patches, 1 OUT patches, 8 SOL patches,
ERROR: Not enough grid level to go from the fine to the coarse grid 0 patches involved in 0 FNMB
0 patches involved in 0 Rotor/Stator
0 patches involved in 0 Turbo NRBC
...done in 0-sec (Virtualizing the patches)
Gone is offline   Reply With Quote
Problem with foam-extend 4.0 ggi parallel run Metikurke OpenFOAM Running, Solving & CFD 1 December 6, 2018 15:51
SU2 Parallel Computation problem Gramanzini SU2 5 September 29, 2018 12:32
problem sampling a plane in parallel syavash OpenFOAM Post-Processing 0 May 7, 2018 10:15
Problem with parallel computation (case inviscid onera M6) Combas SU2 11 January 30, 2014 01:20
Strange post processing resuls for parallel computation of Onera M6 tutorial Akash C SU2 Shape Design 9 August 30, 2013 06:05
