Home > Forums > Software User Forums > Fidelity CFD
Monitor Mass Flow in FINE/Marine
Like Tree1Likes
  • 1 Post By anna_mir
Old   January 22, 2020, 04:11
Default Monitor Mass Flow in FINE/Marine
joaquim is on a distinguished road
I am doing a steady and transient simulation of a flow through a valve in FINE/Marine and I also have two pipes (inlet and outlet). So I have used the EXTERNAL boundary condition for both, with inlet as "Far field" with constant velocity (Vx) and outlet as "frozen pressure".
Inlet pipe diameter: 0.373 m
Outlet pipe diameter: 0.30 m
Velocity inlet in x direction: 1 m/s
Fluid: Water
My question is: how can I monitor the mass flow (inlet and outlet) during the simulation? I have checked the files produced by the solver after the simulation, but I have not find anything regarding mass flow. If it is possible using dynamic library, could anyone please help me with that? I am new using FINE/Marine.
I know it is possible to check after the simulation in CFView the inlet and outlet mass flow, but I would like to monitor during the simulation, just like in FINE/Open, for example.
Thank you in advance.
Joaquim
joaquim is offline   Reply With Quote
Old   January 22, 2020, 23:36
Hamid Zoka
Hamidzoka is on a distinguished road
I wonder why you do such a simulation in Fine/Marine?
Hamidzoka is offline   Reply With Quote
Old   January 23, 2020, 03:07
Hi Hamidzoka,
thank you for your reply. The reason why I am using FINE/Marine is because I am studying the motion of the valve and for that I would like to use overset grid approach. Since overset grid is not possible in FINE/Open, I am doing the simulation in FINE/Marine. Therefore, it is relevant in my case to monitor the mass flow during the simulation.
In case you have any idea how to help me with that, I would really appreciate it.
Thanks
Joaquim
Old   January 27, 2020, 06:03
Anna Mir
anna_mir is on a distinguished road
Hello Joaquim,
FINE/Marine does not include automatic mass flow monitoring as it was not created for internal flows.
But you can monitor the mass flow by saving periodic solutions. If the computation is mono-fluid: Outputs > Probe variables > Surface data. Create two cutting planes, one near the inlet and one near the outlet with velocity saved.
Then in CFView you can compute the mass flow at inlet and outlet with an integral of the axial velocity.
All actions in CFView are saved in a python script that can be recovered in File > Macro > Save All, so you can easily script the mass flow computation.
Regards,
Anna
joaquim likes this.
anna_mir is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
