April 11, 2024, 11:35 |
Export CharLES Voronoi meshes to OpenFOAM?
Bocliff Sutter
Rep Power: 16 |
Fidelity CharLES uses a Voronoi mesh which has properties which are beneficial for accurate CFD results. I'm interested in comparing results on these Voronoi meshes with standard tet, hex, or poly meshes. Is there a way to export Fidelity CharLES meshes to a format that can be read by OpenFOAM?
April 16, 2024, 02:39 |
Colinda
Rep Power: 14 |
The Voronoi mesh format used by Fidelity™ Charles is tightly coupled to the solver discretization and currently cannot be exported for other finite volume codes. Best regards, Colinda |
charles, openfoam, voronoi |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
[ANSYS Meshing] Automated ANSYS mesh export in ASCII (OpenFOAM) format | siny | ANSYS Meshing & Geometry | 1 | January 17, 2020 09:17 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
[foam-extend.org] foam-extend-4.0 gcc errors & maybe paraFoam | powerline332 | OpenFOAM Installation | 3 | May 24, 2018 21:16 |
Ubuntu 13.04 - Allwmake - enviromentvariables | student666 | OpenFOAM Installation | 4 | July 23, 2013 13:58 |
