Home > Forums > Software User Forums > Fidelity CFD
The run diverges sometimes
Old   May 15, 2024, 02:23
Exclamation The run diverges sometimes
Fatih Yaman
fatihyaman661 is on a distinguished road
I am doing a compressor analysis using NUMECA for a company. The work is confidential so I cannot share much detail. The funny thing is that the very same analysis converges sometimes and diverges at other times. But I don't change anything at all. The mesh, the test setup, the model, the boundary conditions are all the same. I just hit run button twice. And the result changes in two.
I use k-w wilcox model and SST model, and both of them show this behaviour. The problem doesn't persist with SA model. I run the analysis multicore on an HPC system that runs on SLURM.
When it diverges; firstly, the residuals act like the way when they converge. They decrease gradually. However, after a point it gives the density negative error and the analysis stops.
What I don't understand is not that the analysis diverges. It is the fact that it converges sometimes and diverges sometimes. Does anyone have any idea why such an indeterministic behaviour may occur?
fatihyaman661 is offline   Reply With Quote
Old   May 21, 2024, 10:44
Colinda
colinda1 is on a distinguished road
Did you already create a support case on support.cadence.com? For such industrial consultancy project I would recommend to do that to make sure to get an expert advice soon.
When you write about "the residuals", do you also look a the residuals for the turbulence quantities? Di you save the solution before divergence and have a look at it to see whether there are any non-physical values for pressure and temperature in the domain?
Best regards,
Colinda
colinda1 is offline   Reply With Quote
diverge, error, indeterministic, negative density, numeca
Ability to run an openFOAM case at specific time Dikkeunit OpenFOAM Running, Solving & CFD 0 May 16, 2020 10:23
CFDEMcoupling run: two identical runs have different error messages minzhang OpenFOAM Running, Solving & CFD 0 April 24, 2020 13:17
fatal overflow error in the FINMES subroutine for CHT run prashant79_ss CFX 5 September 27, 2014 04:54
Cannot run phoenix on linux opensuse 13.1 kde mabal Phoenics 0 June 15, 2014 06:16
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 11:20
