I have a problem with cavitation. The pressure dependent density description for the liquid works fine as long as I do not activate cavitation. But when activating the cavitation I get NaN for the produced species in the first Iteration (although there is no cavitation at the beginning of the simulation at all).
As I using the cavitation model,density of the heavy fluid just can be set as a constant number.Can I using some method to solve this problem? |
hi generally speaking when you get NaN; it means you are dividing by zero ( or a very small number ) or you are trying to take the root of a negative number - of course if we exclude the case that you are using a value without initailization - here are some Hints:
1- try to use a debugger ( i.e. ddd if your code is in c++ ); this will help you to locate the location of the problem. 2- If the above does not help, I suggest that you examine carefully the places where you interpolate flow variables ( wether the pressure or the temperature is wrongly negative ). 3- look at the bright side ![]() at least you know that your problem is related to cavitation, you don't have to search anywhere else! Go directly to the place that handles this term. 4- when you find the place where the error occurs, try to put =>some kind of a limiter<= to avoid the ( non-positivity ). Hoping it would help . . . good luck ![]() |
hi, i'll like to know more about cavitation
compressibility and cavitation!! | xhliu1 | Siemens | 11 | March 16, 2005 07:19 |
HELP!! Calculation cavitation and compressibility | xhliu1 | Siemens | 0 | December 3, 2004 21:54 |
Compressibility In The Cavity Region In Cavitation | Roozbeh | FLUENT | 2 | July 12, 2003 02:02 |
Compressibility | rhydar | CFX | 0 | December 10, 2002 04:55 |
Compressibility in CFX 5.5.1 | Cujo | CFX | 11 | September 23, 2002 13:20 |
