Home > Forums > Software User Forums > Fidelity CFD
compressibility and cavitation!!
Old   March 5, 2005, 21:39
Default compressibility and cavitation!!
xhliu1
I have a problem with cavitation. The pressure dependent density description for the liquid works fine as long as I do not activate cavitation. But when activating the cavitation I get NaN for the produced species in the first Iteration (although there is no cavitation at the beginning of the simulation at all).
As I using the cavitation model,density of the heavy fluid just can be set as a constant number.Can I using some method to solve this problem?
Old   March 14, 2005, 13:17
Default Re: compressibility and cavitation!!
khalid sultan
hi generally speaking when you get NaN; it means you are dividing by zero ( or a very small number ) or you are trying to take the root of a negative number - of course if we exclude the case that you are using a value without initailization - here are some Hints:
1- try to use a debugger ( i.e. ddd if your code is in
c++ ); this will help you to locate the location of
the problem.
2- If the above does not help, I suggest that you
examine carefully the places where you interpolate
flow variables ( wether the pressure or the
temperature is wrongly negative ).
3- look at the bright side
at least you know that your problem is related to
cavitation, you don't have to search anywhere else!
Go directly to the place that handles this term.
4- when you find the place where the error occurs,
try to put =>some kind of a limiter<= to avoid the
( non-positivity ).
Hoping it would help . . . good luck
Old   June 27, 2005, 17:16
ti
hi, i'll like to know more about cavitation
compressibility and cavitation!! xhliu1 Siemens 11 March 16, 2005 07:19
HELP!! Calculation cavitation and compressibility xhliu1 Siemens 0 December 3, 2004 21:54
Compressibility In The Cavity Region In Cavitation Roozbeh FLUENT 2 July 12, 2003 02:02
Compressibility rhydar CFX 0 December 10, 2002 04:55
Compressibility in CFX 5.5.1 Cujo CFX 11 September 23, 2002 13:20
