Home > Forums > Software User Forums > Fidelity CFD
local time stepping and pseudo time
Old   February 27, 2006, 16:26
Default local time stepping and pseudo time
phil
I am trying to understand the basic methods of NUMECA but there are still some things not clear to me. I really hope somebody will help me. So, let's start:
1. NUMECA uses a four-stage explicit Runge-Kutta method to solve the equation: int(dU/dt dV) + sum(F_I*D_S) + sum(F_V*D_S) = int(Q dV) (F_I, F_V: inviscous and viscous fluxes; U: solution vector). What happens if the computed problem is "steady"? 2. On the numeical model page, the user has to specify a CFL-number, which is basically v*Delta_t/Delta_x. I have heard of methods that use a time stepping for steady computations to increase stability. How does it work with NUMECA? 3. Moreover to the general Navier-Stokes equation, a term with pseudo time is added. What does it mean? Is the pseudo time defined by the CFL number?
Thanks-.
Local time Stepping phi Main CFD Forum 0 January 19, 2008 07:38
local time stepping cfdbeginner Main CFD Forum 4 March 3, 2006 04:26
Local time stepping Mehdi Benna Main CFD Forum 1 June 19, 2003 22:26
local time-stepping Pierre-Yves Lesage Main CFD Forum 2 February 19, 1999 17:59
local time-stepping Pierre-Yves Lesage Main CFD Forum 3 February 18, 1999 17:01
