Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
SW Flow Simulation independent results visualizer
Old   February 2, 2015, 17:09
Default SW Flow Simulation independent results visualizer
Mohammed
monofy216 is on a distinguished road
Is there a program (such as FlowViz) or any way that can visualize the results generated by Solid Works Flow Simulation without loading it?? Are these results readable by any post processor (even if not the same performance and functionalities available through SW FS)
monofy216 is offline   Reply With Quote
Old   February 9, 2015, 05:20
Disabled
Boris_M will become famous soon enough
Hi Mohammed,
no, the results cannot be read from the native result files by any other software but if you load the results you can export it to either EnSight (commercial post processing software) or you can export it to ParaView (opensource post processor).
So you need to export it to these tools and for that you need to load the results first in SWFS and then do the export.
Boris
Boris_M is offline   Reply With Quote
Old   February 11, 2015, 01:19
Mohammed
Thank you Boris for your help...this is good enough
Old   February 11, 2015, 05:55
Mohammed
Boris,
Could you please help regarding how to export the results to Ensight or Paraview?
I have tried but unfortunately failed to do so.
Thank you,
Mohammed
Old   February 11, 2015, 09:19
Disabled
Hi Mohammed,
in which way have you failed?
Did the export not work or didn't you find how to export?
I need to know what the problem was to better understand how I can help you.
Boris
Old   February 11, 2015, 10:24
Mohammed
Boris,
I didn't know how to export the results. Couldn't find the the feature in Solid Works Flow Simulation that exports results in any other format to be utilized externally.
Old   February 12, 2015, 07:26
Disabled
Hi Mohammed,
You will have to go to the menu "Flow Analysis" then into "Tools" and then "Export Results...". There you can then select which format you want to export. Besides ParaView and EnSight you can also export results for stress simulation.
Boris
Old   February 12, 2015, 08:43
Mohammed
Boris,
As you can see on the linked picture, the option of exporting results is not available. The only option is to export the results for Simulation and even when I click on it, nothing happens!
Thank you,
Mohammed
Old   February 12, 2015, 08:44
Mohammed
https://lh4.googleusercontent.com/TT...i0k=w1656-h869
sorry, here is the link
Old   February 12, 2015, 08:45
Disabled
Then you have an older version. Try to install SW 2015.
Old   February 12, 2015, 09:09
Mohammed
Boris,
This is SW2015 SP1.1. Is there anything i need to activate??
Old   February 12, 2015, 10:16
Disabled
Oh, sorry I thought SW has the capability. I didn't know that it is only available in FloEFD.
Boris
Use homogeneous results as the initial guess for an inhomogeneous simulation JuPa CFX 5 December 26, 2014 13:44
simulation results don't match with experimental results funquest CFX 2 January 19, 2013 20:24
why different results on same model with cosmosflo 07 and flow simulation09? qihongming CFX 3 May 26, 2009 01:30
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 16:29
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
