Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
SolidWorks FloEFD, Global Variables in Parametric Study
Old   March 9, 2016, 06:45
Default SolidWorks FloEFD, Global Variables in Parametric Study
Snow360 is on a distinguished road
I have made a geometry which I will do an external analysis on. It is defined by 3 global variables I would like to do a parametric study on (In total 12 different geometries).
I have tried inserting these into a design table, but found out you can't put global variables into a design table. I have also tried the "Add dimension parameter" but nothing happens and no dimension is able to be selected as a dimension paramter.
Does anyone know what I can do for this? Or how to use the dimension parameters correctly?
Thanks
Snow360 is offline   Reply With Quote
Old   March 11, 2016, 07:14
Smile
Just giving an update, I figured out a decent solution to the problem.
I have in the parameters variation selected each dimension I used the global variable on (essentially i didnt need them as global variables). I could then group them, so I only needed to change variation once.
This was particularily handy in my linear pattern dimension, where i had both the step and number of patterns changing. I could group both of them and it would variate them both at once.
The bad side about this is that I had one dimension which requires the computational domain to change (i have periodic boundary conditions). So for this dimension I made different configurations for each.
In the end I made 3 configurations with 80 scenarios each. This is much less work then the 12 configurations with 20 scenarios each which I would have used otherwise!
Parametric study by Ansys Workbench Sahar FaPerhu ANSYS 17 August 23, 2017 03:29
Parametric Study - Multiple Configurations in ANSYS CFX kskong CFX 1 June 7, 2016 08:22
Parametric Study victoryv FLUENT 3 January 31, 2013 20:29
Creating many def files for parametric study Chander CFX 5 April 2, 2012 10:48
Parametric Study Murat FloEFD, FloWorks & FloTHERM 1 October 13, 2008 03:20
