July 22, 2016, 01:15 |
Export simulation results for MATLAB
Ashish Anand
Rep Power: 9 |
I have recently started learning flotherm. I want to export simulation result to process it in MATLAB. The simulation is temperature analysis in a cuboid volume. I am able to get results but having trouble in exporting results in tabular formats recognized by MATLAB (excel sheets or txt). Please help as soon as possible. Thank you.
July 22, 2016, 03:23 |
#2 | |
Gabriel Ciobanu
Rep Power: 14 |
What you should do is: 1. place some monitor points for the temperatures you want to have monitored 2. run the simulation 3. go to "Window -> Launch Tables -> Table (in the left side menu) -> Monitor Points. 4. select all values and export to excel is available by right click on the values CAUTION: before going to window -> launch tables don't forget to press F4 on the keyboard in Project Manager. This will reset the project tree view so you get all monitor points in Tables. Enjoy, Gabriel |
July 22, 2016, 04:16 |
Thank you. I was able to do it.
Ashish Anand
Rep Power: 9 |
respected Sir,
Thanks a lot. I was able to export data and use it further. |
July 22, 2016, 04:17 |
Ashish Anand
Rep Power: 9 |
Respected Sir,
flotherm model, matlab, results to excel, results to txt |
Difference between 2D and 3D simulation results | Tuck | FLUENT | 2 | January 9, 2021 17:43 |
export velocity profile and import in an other simulation as initial condition | FFD | STAR-CCM+ | 4 | February 5, 2016 07:27 |
What if my simulation results are far from experiment data? | yanxiaoxu | CFX | 2 | April 11, 2013 09:16 |
simulation results don't match with experimental results | funquest | CFX | 2 | January 19, 2013 20:24 |
Auto Export Transient results? | eRzBeNgEl | STAR-CCM+ | 2 | September 12, 2011 18:31 |
