Home > Forums > Software User Forums > FLOW-3D
flow depth in channel
Old   May 6, 2013, 13:46
Question flow depth in channel
mahdi
mahdi1 is on a distinguished road
Hello dears,
In a part of my project, I need to simulate a channel with horizontal slope.
For inlet, I chose volume flow rate with a fluid height. Also , I considered a length for this channel to reach developed flow. As you can see in attached picture, flow depth is less than fluid height that I had considered in inlet boundary condition.
I want to simulate flow in a channel with horizontal slope (Also with a desired flow depth in channel).
I would be thankful if some one could help me.
Regards,
mahdi1 is offline   Reply With Quote
Old   May 7, 2013, 02:47
Yi-Lang Chen
Andy Chen is on a distinguished road
What did you set up at downstream condition?
Andy Chen is offline   Reply With Quote
Old   May 7, 2013, 04:50
mahdi
Hello Andy
I have tested both cases of Continuative and outflow for downstream.
Do you have an advise?
Regards,
Old   May 13, 2013, 15:29
elephant is on a distinguished road
Your case is a channel that I assume is flowing under subcritical flow, and the water elevation is influenced by hydrostatic pressure downstream. This downstream hydrostatic pressure is caused by some sort of physical boundary such as a reservoir of constant depth or a flow control structure (eg. weir).
In order to model this, you need to set a hydrostatic pressure at your downstream boundary. If you just model it as free outflow or continuative, the water level will drop to the hydraulic grade line, based on the slope and friction of the surface. This is what you are seeing in the output you have posted.
elephant is offline   Reply With Quote
Old   May 13, 2013, 15:44
mahdi
Hi elephant
Thanks
Old   May 30, 2013, 05:28
wusuhong
wusuhong is on a distinguished road
Set downstream as 'Pressure' boundary condition with the same fluid height as you set in the upstream boudary condition.
wusuhong is offline   Reply With Quote
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
Open channel flow motaba Main CFD Forum 4 March 26, 2011 03:22
Yacht in Open Channel Flow andreimour FLUENT 1 October 14, 2010 23:54
Flow within a thin channel al0Vera FLUENT 0 June 15, 2009 10:20
Slug flow in square channel PaulC FLUENT 0 December 5, 2005 02:03
