May 26, 2013, 22:23 |
multiphase flow model (water+oil)
H.A
Good day all
I have multiphase flow model with one fluid (oil+water) in gravity separator tank how can i know the amount or volume of oil mixture in water for flow 3D second question, is there a way to know the oil concentration for example after 100 second from mixture Thanks |
May 30, 2013, 13:57 |
If you're using the 2-fluid model then the mixture concentration is defined by the fluid fraction. You can then measure the volume of each fluid using a sampling volume.
June 2, 2013, 09:39 |
H.A
thanks a lot for your reply dmilano
Kindly if i define the initial fluid regions with appropriate densities (in model setup - initial) fluid region 1 : water density 1000 fluid region 2 il density 800 and i have the rate of oil inside the water 5% , so how much define the fluid fraction for each fluid and where define it in initial or in boundary conditions? thanks |
June 3, 2013, 10:11 |
In two fluid problems the density is computed from the fluid fraction, not the other way around. If you define fluid 1 as water and fluid 2 as oil then you just specify the mixture fluid fraction in the initial conditions and at the boundaries. For example, if you had a mixture of 5% oil and 95% water entering at a boundary you would specify a fluid fraction of 0.95 at this location.
June 5, 2013, 00:24 |
H.A
Dear dmilano
if i choose two number of fluid then there is no free surface (no out flow) in my case i have a free surface separator tank and the inlet flow is mixture between oil and water. which the best model must be use Drift flux source mass or scalars thanks alot |
June 5, 2013, 10:30 |
Sorry - I didn't realize that there was a free surface. In this case you'll probably want to use the 1 fluid drift flux model and specify the mixture density at the boundaries, initial conditions, and sources.
multiphase flow ,mass and volume fraction imbalance | sope111 | CFX | 16 | September 3, 2018 00:10 |
Multiphase Flow with NIST Real Gas Model | Annka | FLUENT | 7 | May 23, 2017 07:58 |
multiphase model, water in air? | bugra | Main CFD Forum | 10 | January 2, 2010 13:09 |
Multiphase flow for flow around ship | gundul | CFX | 5 | September 2, 2008 16:06 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
