November 14, 2013, 16:19 |
Problem with an obstacle in format stl
ouni firas
Rep Power: 12 |
DEAR EXPERTS
I am trying to simulate a weir in a channel, I prepare the STL form and I put it in the channel, but I was surprised by the resultas as the pictures shows, the barrier was crossed by the flow as if it does not exist, although it is imported as a solid, standard |
November 14, 2013, 17:33 |
Jeff Burnham
The mesh is not fine enough to resolve that thin .stl. There needs to be at least 2 (preferably 3 - 4) cells across the cross-section of all solids.
November 14, 2013, 18:31 |
ouni firas
Rep Power: 12 |
thanks for explaining
I drew the STL file with Autocad and I import directly as STL file format, the mesh that I can change is the Block, I do not know how to change the mesh STL? THANKS |
November 16, 2013, 02:52 |
Fatema Zandi Goharrizi
plz clarify your question. what exactly do you want to do?
[ICEM] STL Geometry in ICEM | asal | ANSYS Meshing & Geometry | 3 | February 5, 2013 09:44 |
HelyxOS problem while reading an STL file | HelyxOS | OpenFOAM Pre-Processing | 5 | October 16, 2012 05:58 |
[Technical] How to hex mesh geometry in STL format? | bigphil | OpenFOAM Meshing & Mesh Conversion | 9 | July 6, 2009 12:29 |
stl file format | AMP | Main CFD Forum | 0 | March 2, 2008 00:43 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
