June 2, 2014, 03:29 |
Rotational axis for hydrodynamic screw
Rep Power: 11 |
I've been working on a hydrodynamic screw simulation and I'm having trouble fixing the axis of rotation. I've been able to limit the translation in the motion controls, but when the fluid strikes the screw and starts turning it also bounces it around rather often through other geometry even with the collision model on.
The screw has an angle of 30 degrees if that helps at all, motion is coupled, translation allowance is set to 0 in all directions. If anyone could shed any light on how to fix the rotational axis, I'd greatly appreciate it. |
Axis treatment in axisymmetrical problem | Jakob1 | OpenFOAM Pre-Processing | 2 | August 25, 2014 03:09 |
[ICEM] Rotational periodicy setup | Procyon | ANSYS Meshing & Geometry | 0 | April 30, 2011 07:55 |
Writing Moment coefficient for different walls at different rotational axis | harishameed33 | Main CFD Forum | 0 | April 27, 2010 12:17 |
Defining a moving rotational axis! | Samuel | CFX | 3 | September 12, 2007 10:00 |
Specifiying rotational axis' - a bit stuck | Dave | FLUENT | 1 | August 31, 2007 05:18 |
