Home > Forums > Software User Forums > FLOW-3D
Existing simulation
Old   April 3, 2018, 07:59
Default Existing simulation
SGG
Guillermo
SGG is on a distinguished road
I want to create a new simulation from a previous one, just changing some parameters. i know I need to copy the preping file and change the name, also the STL file, some other file?
SGG is offline   Reply With Quote
Old   April 13, 2018, 19:32
thunde47
thunde47 is on a distinguished road
Ideally, you should be able to create a simulation copy from the GUI itself. But in case you want to do it manually from directories, you may consider moving movin.inp files as well, if they exist.
thunde47 is offline   Reply With Quote
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 02:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 15:06
Waterbell Simulation o.b.m Fluent Multiphase 1 November 5, 2015 05:55
mass flow rate issue in supersonic nozzle simulation xkang FLUENT 0 July 31, 2014 16:06
Axial fan simulation in UG/NX 7.5 fan123 Main CFD Forum 2 April 23, 2011 08:22
