Home > Forums > Software User Forums > FLOW-3D
using Fluent or Flow-3D
Old   April 21, 2019, 16:41
Default using Fluent or Flow-3D
sobhan
sobhan.f71 is on a distinguished road
hello All Users
I want to study the 3D flow structures of a solitary wave propagating
over a submerge porous barrier using LES Model. Which software do you recommend?FLUENT or FLOW3D? Does anyone have any experience at this mater? Which one gives better results for solitary wave generation and Multi-phase+VOF method? Thanks in advance.
sobhan.f71 is offline   Reply With Quote
Old   May 17, 2019, 19:31
Farzam is on a distinguished road
Hi Sobhan,
I've worked with both Fluent and Flow3D. However, I don't have experience in this case (solitary wave propagation).
Generally Fluent have way more sophisticated multiphase and turbulence models, but it is numerically expensive. A free surface simulation that takes a few hours to be solved by Flow3D might take days to be solved by Fluent.
If you have access to HPC, Fluent would be better. If not F3D makes more sense.
Cheers,
Farzam
Farzam is offline   Reply With Quote
Old   June 24, 2019, 18:31
thunde47
thunde47 is on a distinguished road
FLOW-3D has been used to perform similar studies in the past. We have a dedicated waves module with an option for different waves propagation.
Of course, like others pointed out, free surface tracking is the known strength of FLOW-3D. Additionally, we have a porous media option and inbuilt LES model as well. I do not know about ANSYS but FLOW-3D seems like a good option.
thunde47 is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Fluent v15 multiphase flow b.c. failure Non-channel flow mickjazz Fluent Multiphase 1 September 22, 2014 06:41
help for ANSYS Fluent - cylindrical flow slimmsk ANSYS 0 April 17, 2012 17:00
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
