April 29, 2021, 14:36 |
Hybrid Laser Arc Welding Project
N/A
I am a mechanical engineering student and am in a laser class that uses Flow 3D Weld. We have a project that needs to have a hybrid laser arc welding simulation in Flow 3D but my partner and I do not know how to set up the simulation. We just learned how to operate Flow 3D this semester so we are relatively new at it and need some help. Any help would be appreciated, thank you in advance! |
August 2, 2021, 10:10 |
UK
Rep Power: 7 |
Hi. If you are a current customer, you should have access to the users site where we have created a number of WELD examples that you can follow through. This should be your first step. Thanks!
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from | syntex | OpenFOAM Meshing & Mesh Conversion | 19 | December 10, 2018 07:21 |
[Other] Change the mesh in mixerVesselAMI2D tutorial | hoemmaria | OpenFOAM Meshing & Mesh Conversion | 2 | October 6, 2017 07:43 |
settlingFoam unstable? | bendel_boy | OpenFOAM Running, Solving & CFD | 38 | July 8, 2016 05:07 |
[Other] mergeMatchPairs with arcs | vainilreb | OpenFOAM Meshing & Mesh Conversion | 1 | August 5, 2013 08:11 |
[blockMesh] apparently the mesh doesn't want to be created in one direction | Maxime Thomas | OpenFOAM Meshing & Mesh Conversion | 1 | August 18, 2012 06:05 |
