May 17, 2021, 05:09 |
Specifying diverted discharge
timothy
Hi Dear Flow3D users,
I have a linked open channel system (one main and one diversion channel) and I need to specify diversion discharge (as if there is a pump at the outlet). I tried to specify an outflow discharge but there is no such option. How can I do this? Does a negative volume flow rate at outflow work? Thank you for your help. |
May 17, 2021, 18:08 |
Eric Lemont
Rep Power: 5 |
Hi niko35,
I think there are a few options for what you describe. 1) You can use a volume flow rate boundary type with the flow direction vector specified in the direction that pulls it out of the domain. 2) You could also apply a mass momentum source near your boundary that would act as a sink and draw flow from the model. Good luck. Let me know if you have trouble getting it to work. |
diversion;water intake |
section discharge vs time | saravenu | CFX | 1 | January 15, 2016 05:45 |
Need ideas-fuel discharge system | Jan | FLUENT | 1 | October 10, 2006 23:05 |
Need ideas-fuel discharge system | Jan | CFX | 1 | October 9, 2006 08:16 |
need ideas-fuel discharge system | Jan | Siemens | 0 | October 9, 2006 04:31 |
Need ideas-fuel discharge system | Jan | Main CFD Forum | 0 | October 9, 2006 04:27 |
