how to understant the Solidification Drag Model in flow3d |
August 7, 2021, 23:55 |
Zhihao Ren
As claimed in the user manual of flow3d, a darcy-type drag force is loaded to the mushy and solidified region. When Fs = 1, the Fd will be effectively infinite. In many literatures, there will be a small constant in the denominator to aviod division by zero.
Can anyone help to explain the "effectively infinite" and how flow3d deal with the "infinite"? Fd= TSDRG*Fs^2/(1-Fs)^3; |
September 2, 2021, 11:27 |
Rep Power: 11 |
Hello Svenein.
As far as I understand this equation is used only if local solid fraction is between coherent point and critical point which are used defined values. below the coherent point Fd is assumed zero. critical solid fraction is 0.67 as default and TSDRG is 1. So Fd is like 12.5. If Fd is above this value, flow stops. So I think if drag is above the critical Fd value, solver assumes that the flow stops (or drag is effectively infinite) and switches to a different model. |
Adding New Drag Model to MPPICFoam | surajkvs | OpenFOAM Running, Solving & CFD | 0 | May 4, 2018 04:03 |
Foam::error::printStack after adding New Drag model | surajkvs | OpenFOAM Running, Solving & CFD | 2 | March 10, 2018 12:11 |
Solidification Shrinkage and Porosity Model | jk75 | FLOW-3D | 1 | August 13, 2009 22:45 |
Solidification drag coefficient | atulverma | FLOW-3D | 1 | May 14, 2009 09:24 |
multiphase model and drag law | Yasmail AKARIOUH | FLUENT | 0 | April 29, 2008 07:44 |
