Is it possible to create such an irregular mesh in flow 3d? |
April 14, 2024, 11:10 |
sajad mojtahedi
Rep Power: 2 |
April 15, 2024, 00:08 |
Sehroosh
Rep Power: 7 |
Hi. As per my knowledge, Flow 3D built in mesh builder creates orthogonal mesh blocks rather than irregular cells. However if you need a fine mesh around any object within a coarse mesh block, you have other options to do so in Flow 3D.
#flow 3d, #meshing |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
periodic straight tube flow, no mesh independent solution for pressure gradient | thijs1909 | FLUENT | 5 | May 16, 2018 09:04 |
