Home > Forums > Software User Forums > FLOW-3D
Non-Newtonian Fluids Property
Old   February 24, 2009, 19:20
Default Non-Newtonian Fluids Property
Ben
HI I have Non-Newtonian fluids property (viscosity as function of shear rate) but have no idea how to input it into Flow-3D material property. So can anyone advice on this?
Old   February 24, 2009, 20:33
Default Re: Non-Newtonian Fluids Property
HC
If the strain rate is within the upper range during the whole simulation, meaning the stain rate is very high, the carreau equation presented in FLOW3D manual may be simplified as power law if mu_inf happens to be zero. Basically, if you look at the carreau equation, mu_inf = 0; E_T = 1; #given the temperature is constant lambda_00 = 0; lambda_0 = 0; lambda_2 = 0;
From there, you take "Ln" on both sides and it will turn into a linear equation, then you should be able to find the exponential coefficient (1-n)/2 and mu_0.
If the strain rate in the simulation covers not just the upper range, you may send the data to support@flow3d.com and see what else could be done.
Old   February 25, 2009, 00:24
Ben
Hi HC for my case the shear rate is cover entire range, so it is not a linear graph. Noticed that Flow-3d didn't user define function to enable this. anyway will check with support team on this.
Old   February 26, 2009, 23:54
michael barkhudarov
Ben,
FLOW-3D has a fairly general hence complex function for the viscosity vs. strain rate (it's in the Theory Manual). As HC was saying, you'd first need to pick up which terms in it to use, then define the coefficients for these terms. Some coefficients can be determined from the asymptotic behavior at zero and infinite strain rates, and the rest from the fitting. Obviously, the more terms you use the harder it will be to do the fitting.
One can also introduce a user-function unto the provided FORTRAN function, but this will require programming and compiling.
In this year's release the user will be able to define the non-Newtonian viscosity tabular input.
Michael
Old   February 27, 2009, 00:58
Ben
Hi Michael It good know about the improvement made on non-Newtonian input, do u have any idea when the new release will be available?
Old   March 1, 2009, 01:42
michael barkhudarov
We are shooting for the end of summer.
Old   April 21, 2009, 12:03
Default viscoplastic model
xianghong wu
wendywu is on a distinguished road
Originally Posted by michael barkhudarov
;93241
HI,
I am wondering if viscoplastic model could be input when you release the tabular input? Thank you.
Wendy
wendywu is offline   Reply With Quote
Old   April 26, 2009, 22:52
michael barkhudarov
MuxaB is on a distinguished road
I don't know. What does the viscosity depend on in this case?
MuxaB is offline   Reply With Quote
Old   April 28, 2009, 10:57
Default viscoplastic model depends on strain rate and temperature
xianghong wu
I will use the constitutive model according to Bas Jan Emile van Rens's thesis: finte element simulation of the aluminum extrusion process shape prediction for complex profiles. the constitutive model is as attatchment.
Thank you.
Wendy
two mixing compresible fluids solver ziemowitzima OpenFOAM Running, Solving & CFD 27 August 13, 2020 12:40
Using non-Newtonian fluids in Fluent Irene Fyrippi FLUENT 11 September 28, 2015 14:28
Low reynolds model for non newtonian fluids Kimo FLUENT 0 July 22, 2007 11:36
Differents fluids separated by wall phil FLUENT 0 January 18, 2007 02:43
spraying non newtonian fluids IƱigo Main CFD Forum 0 October 4, 2005 09:36
