July 18, 2009, 09:17 |
Absolute pressure
amirhossein meysami
Would you please tell me how can define a absolute pressure in fluid? because, when I simulate a free surface and define a void pressure in top area, a logical hydrostatic pressure does not form. I am modeling bubble formation on a hot rod, also I active cavitation model. best regard |
July 20, 2009, 10:14 |
Stefano
if you are using the gravity, and you set an initial pressure with absolute values, then you'll have in your calculation absolute values of pressures.
July 21, 2009, 02:55 |
amirhossein meysami
Dear Stefano
Thank you very much for your answer. I set gravity and initial pressure with absolute valie, but the pressure was very variable during solving. would you please tell me where are there any mistakes? I must tell you that I have active bubble phase change mode in this calculation best regards |
July 21, 2009, 04:13 |
Stefano
hello meysami,
it is hard to understand what happens in your simulation. I would need more informations. But you can start to look in the online manual, at the chapter "How do I model", to check if you are modeling the bubble with all the data needed or if something is missing. |
July 21, 2009, 05:21 |
amirhossein meysami
Dear Stefano
Thank you very much. For bubble modeling I have checked every thing many times, but unfortunately I have not gotten correct answer and the pressure varies during calculation, I do not understand why pressure is variable, if possible for you I can send my perpin file to you via email. I will very pleasure that you help me for solving this problem. I am waiting your answer Best regard |
July 21, 2009, 05:37 |
Stefano
if you use the bubble model then it is right that the pressure changes: it will change following the equation of state of the gas.
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
