Home > Forums > Software User Forums > FLOW-3D
rotating spring in fluid
Old   August 28, 2009, 02:35
Default rotating spring in fluid
s Kumar
doctsh is on a distinguished road
Hi
i want to study rotating helical spring in low-Reynolds number environment. How to model it in flow3D or any other software. please somebody answer it!!
doctsh is offline   Reply With Quote
Old   September 1, 2009, 10:46
Stefano
stefmascio is on a distinguished road
just load your helical spring in .stl format inside the software, and give to it its rotational speed (GMO model, prescribed-fixed axis motion).
But you would need a very thin cell size if the thickness of the spring is small.
stefmascio is offline   Reply With Quote
Old   September 2, 2009, 01:13
Default would you please illustrate little?
s Kumar
Thanks a lot for your reply.
As I am a biology teacher, completely new to flow3D and i am learning. Would you please tell me briefly, how to create a very thin helical spring(actually it is bacterial flagella of few nm thickness) in .stl format?
I would be very thankful, if show me steps to do that.
With regards
doctsh
Old   September 2, 2009, 08:21
Stefano
it seems a very interesting application!
To draw your flagella you have to do it in any external CAD software, and then save it as a file with .stl format.
Then with FLOW-3D you can easly import it in the "Meshing&Geometry" tab.
But do you have already done any fluid dynamic analysis (also with other software)? The first time could be quite difficult to get to a good result.
Old   September 2, 2009, 10:12
s Kumar
Dear stefmascio,
thanks again for yout thoughtful reply.
Though I have studied fluiddynamics and physics, i have not used any CFD software. I am struggling with this for long time, but i wanted to solve this using simulation as it is difficult to model in a macroscopic scale.
Do you recommend any other software for this application?
I want the flagella to be rotatated and thrust should be calculated. I want to see the emprical relationship between viscocity, rpm, thrust etc.
I really dont know how to proceed further. This is an important step in my research. without that my four years of research will cometo standstill.
Can you help me to come out of this?
ERROR #001100279 for a Rotating Fluid Domain Fonzie CFX 3 August 24, 2010 19:42
[GAMBIT] Rotating Cylinder Full of Fluid 1337Hal ANSYS Meshing & Geometry 4 April 7, 2009 03:38
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Fluid in a rotating cylinder Fluid Novice Main CFD Forum 1 December 17, 1998 17:25
