January 4, 2010, 02:56 |
import topographical
Yi-Lang Chen
Rep Power: 17 |
Dear experts:
I want to import topographical to FLOW-3D. I have the ASCII file. The file have x- y- z- coordinate. How did I convert ASCII file to STL? Thanks your help! |
January 5, 2010, 09:07 |
PEPIN Nicolas
Rep Power: 16 |
Hi!
It's really easy to import a topographic file. You don't need to convert it as a .stl. Open your ascii file with a text editor and be sure that the columns are separated by a space. Then add a title line: "X" "Y" "Z". Your file should be like the following example: "X" "Y" "Z" 1015372.75 194868.25 282.219 1015373.00 194868.25 282.438 1015372.50 194868.00 281.382 1015372.75 194868.00 281.127 1015373.00 194868.00 281.621 1015373.25 194868.00 282.336 1015372.25 194867.75 280.545 Save your text file and rename it as "name.topo" (change the .txt into .topo). Finally, in order to import your file in Flow3D, click on your file in the "Add Geometry File" window, after having selected Files of type: *.topo topo*.inp. Good luck! Bye! |
January 5, 2010, 11:46 |
#3 | |
Yi-Lang Chen
Rep Power: 17 |
January 7, 2010, 03:46 |
Topographic - Hydrographic Survey
Sumit Kumar Tyagi
Topographical Survey is the study of Earth's surface shape and features.Topographic Survey is used to determine the position of any feature or more generally any point in terms of both a horizontal Coordinate system such as latitude and longitude, and altitude. Identifying (naming) features and recognizing typical landform patterns are also part of the field.
For more details about topographical survey, visit the following below link. http://xploreronline.com/Projects-Ar...IS-MPR-5-.aspx |
Mesh and geometry import in cfx-pre | Francesco | CFX | 7 | May 30, 2012 08:04 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Import Pro/E to CFX | Cory Miller | CFX | 4 | September 25, 2006 12:21 |
import mesh problem | Wendy | CFX | 2 | February 6, 2002 05:39 |
I-DEAS CAD data import with boundary conditions | Yunus | FLUENT | 2 | March 14, 2001 14:45 |
