Home > Forums > Software User Forums > FLOW-3D
F-Packing Function
Old   February 5, 2010, 02:39
Default F-Packing Function
ck5285 is on a distinguished road
All would like to know if anyone did compare results between Default f-packing vs Reduce surface breakup in extreme cases? Is the 2nd option run slower due to additional surface treatment needed to prevent breakup of fluid?
ck5285 is offline   Reply With Quote
Old   February 10, 2010, 09:35
michael barkhudarov
MuxaB is on a distinguished road
The difference in speed between different F-packing options is minimal. I doubt it will even be noticeable. The difference in the results depends on the type of problem and in many case is also minimal. I would recommend sticking to the default setting.
MuxaB is offline   Reply With Quote
Old   February 10, 2010, 19:51
Hi Michael, thanks for clarification.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
